Hi folks, finally got around to taking the inlet manifold off today. When I lifted the carb pedestal I noticed there was a small pool of oil in the bottom of the manifold and when I removed the manifold itself the runners were quite black and oily as were the inlet ports in the heads. This would explain my mucky oily plugs and the white smoke I'm getting; trouble is I can't work out why it should be drawing in so much oil. I lifted the rocker cover that the breather is connected to and there was certainly no pool of oil underneath - just what you'd expect around the base of the cam lobes etc.
Anyone got any ideas as to why it might be pulling in so much?
