I have a car withthe HRS Holley fitted.
The idle speed was way too high and could not be lowered even after checking the shutting off of the primary and secondary valves. I found that the carb was getting too much air from a large vacuum intake (on theRH side)which was connected to the cam cover breather.
I have now blocked off this intake and connected the engine breather to theair cleaner. This now idles and runs fine.
Which breather connectiondo you use on yourHolley setup?
The other problem is bonnet clearance. I have checked the carb base and air cleaner and both seem to be properly seated, but the carb sits too high and hits the bonnet pad/bar. The bar is tight upagainst the bonnet padso thats not the cause.
Is this normal?
Is this normal?
