Hi all,
Having started up my Stag for the first time after doing a hose replacement & coolant flush, I was alarmed to notice fuel dripping off of the back of the engine onto the drive. Investigation revealed that the fuel seems to be leaking out of the bottom of the RH carb and running along the vee. From what I could see the culprit is a leaky plug on the bottom of the float chamber, as it seems loose and I can spin it round with my fingers. The plug on the non-leaky LH carb is tight. I assume therefore I must have nudged it when replacing the coolant pipe to the heater.
I'm somewhat puzzled however because the repair manual shows this plug to be threaded - screwing in and sealing with an O ring, but unless it's sheared somehow or the thread is stripped, which I find hard to believe, the leaky one just goes round and round, and appears to have no thread.
Can anyone enlighten me on this one - I'm currently a novice as far as the carbs are concerned, and I'm hoping the fix is simply to whip off the carb assembly and replace the plug and O ring.
Thanks in advance.
Regards,
Bob
Thanks in advance.
Regards,
Bob
