my 72 Mark 1 previously had electronic ignition in it, but when I bought it it had been returned to points.
I drove it home no problems (200 miles), but then had a coil failure later - I replaced the coil with the Rimmers standard 9 volt - and also did all the points, capacitor etc - the coil burned out again after about 100 miles running.
I subsequently discovered that the carhad been fitted with the 12 volt coil and the ballast resistor removed when the electronics were put in, and this set up left on the return to points............................ so I'veput it all back to how it should be, 9volt, balast resistor......................but,
i've got an on going problem with the Tacho in that it bounces around a fair bit, it also seems to "jump" without changes to engine speed - any ideas???? could it be the tacho itself (how can I check it)?, what about the voltage stabiliser (I haven't investigated that yet (again how do I check it?). Something else?
PS I'm certain that I have it wired as per the book diagram - oh and the other dials all seem to work fine.............:?
