Fitted a new throttle cable recently and now I can't seem to get the idle speed below 900 rpm. Unscrewed the two idle speed screw on each side of the carbs but can't get it to tickover lower. If you manually pull the levers back a fractionit drops down to 650-750. Is something sticking? The throttle cable and both choke cablesdon't seem to be stopping it releasing.
Des
Des
