Cltch release bearing
    having removed my gearbox, I had a look at the clutch release bearing, as now and again I get a bit of a screeching noise coming from the gearbox area.
    There is a bit of play in the bearing if you rock it top to bottom, backwards and forwards, should there be any?
    There does not seem to be any harshness in the bearing at all.
    Rgds....Al.
    Al,on the TR6 some peopleuse a heavy duty release bearing from a Toyota Hi Lux,not sure what year Hi Luxbut TRGB(01487842168) sell them,I woulda thought they would be the same as the stag.
    Mark
      Rgds....Al.
      Al what clutch are you using? ,my bearing from paddocks has been sent back and i'm waiting for a replacement because it felt a bit rough.I've just looked at the old one and it is perfect with no movement in any direction (except rotation).If i go with the new paddock bearing you are welcome to this one and i know it is very quiet.
      Cheers Steve
        Rgds....Al.
        Cheers Steve
        Cheers Steve.
        The clutch is Bork & Beck, so assume release bearing is all part of the same.
        Al.
