CUSTOMER SERVICE ( NOT ) !
    Hi All
    Just thought some of you might be interested in this - especially when you come to buy parts for your Stag. This could also be read/linked to V-Mads recent poll about parts suppliers.
    So - ordered a new front valance and a passenger side front inner wheel arch repair section. Got an email the next morning confirming items dispatched -so far so good. Got home from work at around 9.30pm -large box in hallway - deep joy at parts arriving so quickly - good service !
    Got clearance from SWMBO for trip to garage the next day - so loaded van with large box and tools and headed off to garage with a grin and my head full of plans for the day.
    Unload van - get settled in to garage mode - open large box. Removed valance - examined for damage (none) - remove inner wheel arch repair panel.
    Set up equipment - welder/ disc cutter/ lead light etc then offered up wheel arch repair panel to mark out where to cut out old - funny , seems wrong shape - realised very quickly it was a drivers side repair panel ! examined panel and it has sticker clearly stating NSF !
    Got on the phone to try and sort out the problem - when I explained to the personat the suppliersthat I had been sent osf instead of nsf, I was asked is the taper to the panel to the front or rear. I pointed out that regardless of which side I was looking at, be it nsf or osf both panels would be tapered to the front with the rear of the panel being straight (to join to splash panel) in relation to how they fit.
    I was gobsmacked when I was told"if the panel tapers to the front you have the correct one" - I suggested that the one that I had been sent was incorrectly labled and could that be checked with the stock that they had. After a brief interlude I was greeted with the information "all our stock has NSF stickers" - to which I commented that all their stock of that item is possibly incorrectly labled. I was told "we cant sort this out now - someone will ring you monday."
    Monday is here and I get a call - I go through the whole thing again and ask what they are going to do for me - answer - nothing - not until I send back the wrong part.
    I said that as its the wrong part I require the correct one to be sent and they could include a franked label or whatever to return the incorrect one.
    Well it wouldseem that despite what they say the customer is not right because I have to mess around packaging up the wrong part, spend my time driving to the post office , pay to park,queuing up ,paying for the postage and waiting the best part of a week to get a replacement !
    I don't get a replacement unless I send the old one back first and then they will refund the postage.
    Not acceptable - I told them I will have my money back and they will lose me as a customer - their attitude was "whatever"
    Ok - rant over - I just felt I needed to share this experience - I would point out that I have used this supplier for 20 years, have spent a lot of money with themand have never had a problem - until now - now I know why they don't rate very highly in the recent poll.
    Ray
    Sorry to hear that Ray - what a nightmare.:X
    Is the supplier the one that starts with R and ends in S with seven letters??
      Ha ha that made me chuckle - I have to say that I couldnt possibly comment as I do not wish to incriminate myself !!
      Ray
        I have been investigating an engine oil leak. with the gearbox clutch and flywheel off the guy who rebuilt my engine came round this morning to have a look and reckons it is the rear crankshaft oil seal.
        He said, no problem he will sort it out, and get another one from you know who...:shock:
        No! It is ok I said, I have some other bits to get so I will get one from elsewhere thank you very much!!
          Al, I got all my seal from Peter at LD including the rear crank seal .It fitted the housing much better than the old one (which nearly fell out on its own)and was tighter on the crank.
          Cheers Steve
            Ray, what's this about incriminating yourself? Are you secretly guilty? If not, name the guilty ones!
            Your post has created over a hundred guessers already!
            chris
              chris
              Agreed; it isjust a rantthat's a waste of bandwidth and unless you're prepared to name the supplier I don't see the point of the post.
                If its the supplier I/we think it is. This is exactly my experience of them. I bought a recon exchange overdrive from them that leaked oil. Completely uninterested in changing it and very abrupt, almost rude, about the whole thing. I buy from them now only if the part is inexpensive and only as a last resort.
                  If you report only the facts, and tell the truth, you are not breaking any laws. Freedom of speech is one thing we do have left.
                  I am afraid I agree that reporting problems without naming is not only a waste of time, it's frustrating.
                    Errr, sorry to be so naive here but........
                    - you dealt with a company for 20 years without a problem and were very satisfied.
                    - you ordered a part and almost overnight it was dispatched.
                    - the item arrived within that same day.
                    - due to a labelling mistake from the panel manufacturer, the packer put the wrong item in the box.
                    - you rang up (on Saturday?) at which time normally only counter service bods are there and they said someone would call you back Monday - which they actually did!
                    - they offered a straight replacement and asked you to send the old one in (which I think you would have to do no matter what the actual sequence of events is)
                    It sounds as though, at this point, you exploded and the chap at the other end said "whatever"
                    Now this Supplier is to be "named and shamed" ? Errr.. precisely what for?
                      Well said, You are not naive.In the real worldmistakes happen. One of the top companies on the recent poll gave me terrible service so should they also be named and shamed ?. The company in question complained about in this post ( Rimmers ) seems to always be slated, sometimes correctly but they have been the only ones who have come onto this message board to explain and help ( happened a couple of months ago ). When we need that "special" part where else do we go ?. I have always been pleased with Rimmers as withmost of theother companies on the pollbut I ask a question, where would we be withoutRimmers ?.
                      Don Kennedy
                      P.S. I have no connection with Rimmers or any other company.
                        I think the difference is that Rimmers is a retail company making a margin in supplying parts or our cars and all of the other suppliers know the cars and are familiar with teh parts and know what we want. It will never change as the company is too big.
                          Don Kennedy
                          Couldn't have said it better myself Drew and Don. I know it's easy to kick the big boys but one problem in 20 years sounds like a pretty good track record to me !
                          Yes they're a big company and they'remotivatedby making money rather than by the love of Stags butI can't help but thinkthings would be a whole lot tougher for us without Rimmers website and their excellent catalogue - I do find it very hard sometimes finding the correct part from all the other suppliers.
                          It's early days for me, I know, but I've had one minor problem with Rimmers and they sorted it immediately at no cost to me, and some cost to them.
                          Give them a break guys - as Don said, "where would we be withoutRimmers ?"
                            Well gent's I have knocked Rimmers in the past, but more for their prices compared with some of the others. Bought replacement diff from them in the summer. 65 miles later saw that oil was coming out of output flange area. Took the diff of dismantled it and found that the lip seal would not do it's job because of old corrosion / pitting.
                            Contacted Andrew at Rimmers, sent him some photos, he agreedand he dispatched the new output flange next day. Just told me to pop the pitted one in the post. No problems at all.
                            Only thing was that it was a pain having to do the job twice. I did mention this to Rimmers, but got little response as far as that was concerned!!!
                              hi ray its about time you woke up about rimmers all the crap bits we been sent over the years ie naf crankshaft , wrong shocks waiting weeks for carpet sets bolt kits ect ect ect i would pay more from other traders than use them
