HEAT SHIELD
    HEAT SHIELD
    On the mk 2 there is a heat shield on the n/s exhaust manifold .Now I have the Weber carb mine is surplus to regiments so I was going to remove it but the bolts are seized what I need to know before I snap one is,do the bolt hold the manifold on as well or is it just the heat shield it holds on
    JOHN
    Hi
    As far as I can remember the bolts are screwed into blind holes and do not have anything to do with the attachment of the manifold itself, so snapping the bolts off won't be a disaster.
    Glen
      Thanks glen will remove in
      JOHN
        Just removed mine so I can confirm that!
        By the way, I found no way of getting the heatshield off whilst the manifold is still in place, despite the screws coming out easily!! (Still, if it's scrap you can get anangle grinder on it!)
          Thanks dasadrew
            Hi John
            If you have no further need for the heatshield, may I have it?
            Bruce
              Rubce wrote:
              Hi John
              Bruce
              Hi Bruce
              If it comes of in one piece its yours
              JOHN
