Accidental reverse gear selection
    My modern car has a six speed manual gearbox, and I often find myself trying to select a phantom fifth gear in my MOD Stag. This means trying to select reverse at 50 mph and catching myself (sometimes).
    Should the gearbox have a reverse lockout or has it always been possible to just push across the gate from 3/4 plane?
    Chris
    Magenta Stag TV8 MOD
    As I recall the selector rod for reverse has a slot that is slightly higher than the other rods and in the Base of the gear lever there is a spring loaded device that should prevent you accidentally engaging reverse . You may have lost this spring .
    Graham
