Radio Aperture
    Radio Aperture
    Afternoon learned ones. I decided to renew my dashboard and fit a retro look radio with Bluetooth etc. The radio is a standard DIN size which matches the aperture in my existing veneered panel. However, the new (second hand!) panel has a much bigger hole in it with four ‘lugs’ cut out and the radio cage just falls through. The gap is a good 6-8 mm all round so it’s too big to fill and I suspect that there isn’t room to reinforce it from behind. It looks OE as it is very neatly cut, which leads me to suspect that my existing radio panel is a custom job.
    I see that some suppliers sell an adapter, for quite a lot of money, but they don’t look as though they will support the cage and radio adequately to me. Does anyone out there have any views or pictures of one of these in situ, please?
    David
    I used the mounting plate sold by Paddocks - think it was ~£25 - just the job, though needed some minor fettling with a knife to square-off the corners. It happily supports the DIN CD/ radio/ Handsfree etc without needing any rear fixing. Had to insert a couple of spacers between the radio cage and adaptor to get adequate rear clearance.
    Think Robsport sells the same adaptor. Well worth it after b*ggering about trying other solutions. It does exactly what it says on the tin!
      Brilliant, Jonny, thank you very much. I’ll order one right away. By the way your dash lights are the absolute business.
      Thanks again.
      David
