Flasher Unit for LEDs
    I changed most bulbs to LEDs recently but discovered i had to get a Flasher Unit compatible with the indicators. Unfortunately the unit is completely inaudible whilst motoring with the hood down. Has anyone found a suitable 3 prong Flasher Unit with either a loud click, chime or buzz? The supplier of the Unit, that I had already bought, suggested that I cut holes in the plastic of the unit to let the sound out!!
    Alex
    Here you go, it will need the earth connecting to work.
    12 volt 2 / 3 pin. Suitable for LED & filament bulbs. Constant Flash Rate stops hyper flash cars & motorcycles EP35 FET13 1H0953227 191 54237009 FL19 111953227D SFB162 SFB190
    Chris
    Magenta Stag TV8 MOD
      Got my flasher relays with my bulbs from Gill at better car lighting, he also supplied a buzzer unit to connect across the warning lamps.
      worth giving him a ring as you know it will work ok with LED's
      Phil
        Thanks to both Carboy0 and Phil. Have tried both the suggestions. Classic Car LEDs was the place that suggested putting holes in their flasher unit - didn't want to try that!. Gil at Better Car lighting was, as you say extremely helpful and I tried his suggestion but wanted to know if anyone knew of a more elegant solution than a buzzer wired across both indicator circuits. Surely someone out there has, by now, designed a flasher unit with an integral "loud" click, chime or buzz.
        Alex
          Alex
          Would this do?: https://www.spiyda.com/flasher-unit-for-led-lights.html
            That looks the biz. Have ordered one from spidya, will advise how well it works once installed.
            Alex
              Have installed subject flasher unit and "it does exactly what it says on the tin". If anyone else is in a similar position, I can thoroughly recommend the product and the service provided by the seller(no connection). Well sorted.
              Alex
