Door Glass Frame
    Door Glass Frame
    Hi All
    before l strip the door panel trim, is the chrome door glass frame slightly adjustable.
    l ask because l have no gap at the top of the door to the B post, but have a 12mm gap at the top of the glass frame to the B post.
    the car was painted by a PO and lm not sure if it has been fitted correctly or can be adjusted to some degree.
    thanks
    Phil
    Lots of movement available in all directions when all the screws on the attaching brackets are loosened!
    Drew
      Hi Phil , yes there is some adjustment , i will go and take some photo's in an hour or so, so you can have a look, as my door panel is still off and are out there working on it.
      But the frame moves in and out at the bottom which moves the top of the frame towards the rubber or away, i also got some adjustment front to back, but will add the photo,s
        This gallery has 4 photos.
          Thanks chaps, another one for the to do list.
          Phil
