The white/blue Bavarian Stag has been completed, so to speak, since about a year but hasn't been totally trouble free. To be honest, it's not been all bad and the real taxing issues have been centred on the engine cooling. There were several incidents which could even merit their own thread but which have hopefully been sorted now:
- the first runs out were plagued by some pretty hefty overheating which I finally traced to the "new, refurbished" water pump which didn't seem to be doing anything. I then acquired an NOS BL pump and that cured the circulation issue. (The overhauled pump had an impellor fitted which, according to the part number, is a Dolomite one. Impellors are often sold as being suitable for TR7/Stag/Dolomite but experience has shown that there are dramatic dimension differences even if they look more or less the same)
- the next runs out still saw me losing some water and, when the filler neck on the "new refurbished" radiator came off in me hands I took the radiator to a specialist who also diagnosed microleaks from the entire matrix where waater had been escaping. A new 'outright' remanufactured rad went in and that sorted the gradual water loss.
- temperature was still on the high side in summer so fitted a Revotec and that did its job in queues in town at 30°C outside temperature. Then discovered that the take-off in the RH transfer housing for the capillary gauge runs about 5°C hotter than the original LH take off point so became less concerned about the needle being a bit on the "H" side of the "N"!
Now comes the Armageddon bit where I'd welcome all suggestions, comments, ideas or soothing words!......
Going out on a longer run in hot summer all hell breaks loose.... car enveloped in its own steam, overtemperature buzzer screeching .... Pulled in rather sharpish and eventually discovered that a core plug had popped out of the LH cylinder head!!! Let everything cool down, got a bucket of water from a local farm and limped home in very short soft bursts with continuous topping up and cooling off. Fortunately I was only a mile or so away from home.
Over the next week or so I managed to remove enough components to be able to get a new core plug in, reassembled all, and off we went again in very close circular routes around the house. All's well, temperature ok now that the hot summer had gone, no water loss and eveything hunky-dory tickety boo. (small carb flooding incident but unrelated to the above and quickly solved).
On one of these exploratory trips can you believe it? The second core plug popped out of the LH cylinder head. Fortunately this time I could more or less coast home to the garage.
The car is now in the freezing garage with heads, water pump etc. all off, stripped down, cleaned, inspected and all the rest. I have noticed that the alloy heads and attaching bits don't seem to be as forgiving as the old iron Pinto bits I'm more accustomed too with respect to gaskets (e.g. on water transfer housings) sitting and fitting 100% and I noticed that most bolts could have done with being nipped up a bit. I'm certainly going about this re-assembly a lot more meticuously than the first time round and being particularly sensitive when I see any alloy porosity on a sealing surface.
The bottom line is that I can't for the life of me work out why I lost two core plugs on one cylinder head. Albeit in iron engines, they've not exactly been the first core plugs I've fitted. I did use a smear of Hylomar which I could maybe suspect as having got overheated and started acting more like a lubricant than a sealant, but why suddenly just on the LH head? And what sort of pressure would be needed to blow out core plugs??!!!
I've inspected the Payen head gaskets and they both look perfect with no signs of leaking or blowing anywhere. Thermostat has been in a hot water bath and opens and closes as it should. Head and block surfaces look perfect and straight. A steel ruler check with my thinnest feeler gauge (5 thou) showed no warping. (The heads had been treated to a very light facing skim before assembly).
Any ideas folks??
Drew
Any ideas folks??
Drew
