I have just taken the engine apart After the water pump sized and shredded the Jack shaft also propelled it self up into the water pump cover killing the pump and cover
number 7 cylinder has had water in it which has left pitting
the engine has been re bored to +40 so if all the rest measure up ok it will need lining
number 2 piston has score marks and kinked oil ring BUT no marks on the bore
RH cylinder head is in great shape and looks like it's never been skimmed
LH cylinder head is the complete opposite and looks like I may get away with one more skim
so my question is another block and re use my plus 40 Pistons or line all the bad cylinders and get new rings .I plan on doing a stagdad Essex water pump so the Jack shaft and water pump cover will be ok
Any advice would be FAD
TA Mucho
Rich
s
TA Mucho
Rich
s
