Hi all, my PDWA is giving me a headache and i'm not sure what to do next. I replaced the seals and bled the system last year, managing to centre the shuttle and extinguish the brake warning light. However, for some reason the light has decided to illuminate again. So i've tried bleeding the brakes again but i'm yet to hear that re-assuring clunk when the shuttle centres itself and the warning light goes out. Any ideas (apart from removing the bulb) appreciated
PDWA switch
Take the switch out,you will not lose any fluid, now use a small mirror and a torch to look in the hole left by switch you will see a v if not it has gone left or right ,use small sharp screwdriver or scribe to move it to middle. good luck. IF the v is in middle, you have an issue with the light or switch. the light eliminates when switch goes to ground or earth.good luck Terry
Originally posted by Sarge66 View PostI had a similar problem a while ago. It turned out that the oil pressure switch wire had somehow become disconnected. As the PDA and oil pressure switch are interconnected simply reconnecting the wire solved the problem.
JonnoWhite 1976 build ("Mk2") only a few mods
Cheers guys, thanks for the great response........is it that easy to manipulate the shuttle, do I not need to bleed the brakes at the same time to allow the shuttle to move (to simulate fluid loss)???
Regarding the switch, I did wonder if the plunger had developed a fault and was now sticking out too far and activating the light, but I can’t find my old one (which was faulty and covered in brake fluid) to compare it to........
Btw, it is a mk2 and connected to the handbrake rather than the oil light.
Make yourself one of these to hold the shuttle central while you bleed the brakes, may be you still had some air in the system that made the shuttle move and illuminate your light?
P1060689.JPG"The UK,s 2nd Most Easterly Stag" Quad Exhaust- ZF 4 Speed BOX
Originally posted by Sarge66 View PostHi Jonno
I can assure you that my car is a MK2 and that the brake warning light is farther both by the PDA and the oil pressure switch as described in the manual. A fault on either circuit will cause the light to glow.
Hope this is helpful.
Noel
Jonno
Hi Jonno
I have copied the wiring diagram that I used to solve my problem referred to in my earlier post and the digram is shown below. I offer this information not as a Stag expert (still learning) but in the hope that it may help others. As you will see it clearly show the interconnection of the oil pressure switch and the PDWA. The manual I referred to is Publication Part Number 545162 and further details are contained in section 70.
Noel
Originally posted by Sarge66 View PostDiagram referred to in my earlier post.
Noel [ATTACH]n757203[/ATTACH]
Bottom line - if the PDWA light comes on with the handbrake - it's as for LD20001 on. Otherwise, it's likely to be for up to LD20000, or is part of the transitionary production.
JonnoAttached FilesWhite 1976 build ("Mk2") only a few mods
