Exhaust smell when top down
    As the title says - with the top down there is a strong smell of exhaust and it clings to my clothes - any solutions? With the roof up the smell increases when I open a quarter light so I'm going to replace the boot seal first but surely with the top down there should be no suction through the boot?
    jon
    Check the boot seal and for any unplugged holes in boot floor.
      Check the grommets on the front bulkhead are all properly fitted.
        Thanks guys, I'll look at both those areas.
        Jon
          I get exactly the ame thing. I thought maybe it was to be expected for a car from the 70's.
          I couldn't remember if I had that smell when I had a Stag in the early 80's. And if I did, never noticed beacause perhaps most cars gave off that smell back then.
          It's even worse when stationary for a while when the roof is down. No smoke from the exhaust and it doesn't use any oil to speak about.
          I remember once, the boot lid popped open, the roof was up and the smell was really bad.
            jon
            Always the possibility of a leaking joint somewhere. You could try covering the tail pipes with your hand and see if the car stalls or it continues to run roughly allowing gases to escape through a gap somewhere. Given that the V8 is a somewhat noisy(in a good way) it might not be obvious that there's a leak. Just a thought.
              I would check the exhaust first.
              In the meantime I wouldn’t get stuck too long in traffic.
              Andy S
                Also check by and around gear lever. I had a car once with same problem turned out to be a leak around the rubber gaiter.
                  Also there is a gaiter on the underside of the handbrake lever, mine had disintegrated
                    Drive faster
                      Pop into an exhaust place and put it up on the ramp. they'll soon tell you if there's a leak
                        ... even if you don’’t
