thread size of temp. compensator on carb?
    Hi everybody
    Can someone tell me please the thread size for the temp. compensator fixing to a Stromberg CDS 175 carb.
    Originally posted by 1005hansjoachim View Post
    Hi everybody
    Not sure which thread you mean. There are 3 different sizes on the compensator. I have detailed them below:
    1. Compensator body to carburettor screw. (2 larger slotted head screws) 2BA
    2. Compensator adjusting screw on the "spring strip" under the plastic cover (2 pozidrive) UNC 6-32
    3. Compensator plastic cover securing screw (2 small slotted head screws) 1/8" Whitworth
    Don't you just love the mix of thread types!
    I have checked these on a "new" untouched Stromberg, removed the screws and run a die down the thread to double check.
    Hope this helps.
      What no metric sizes !!! What a mixture!
      Very good of you to research all that lot.
      '72 Manual O/d Saffron Yellow
        Sorry don't really do metric but there still could be, I only checked 3 threads and they were all different! I think the real reason is getting a coarse/deep thread to go into the alloy body. A lot of small diameter threads would be too fine and strip easily.
        Weather is cold, wet and windy here so couldn't get much done outside - and it satisfied my own curiosity - also had to sort out drain plugs with a 1/4" NPT thread for a friend so 2 birds with one stone etc.
          Thanks Roger
          yes I need the 2BA screws. Probably available at Halfords?
          No time for mail order as I know somebody who can take them for me at the weekend from the UK.
            Thanks Roger
            The stuff I've bought from this guy arrived in a simple envelope in the post a day after ordering! He might have what you need. In any case, a great source in Germany for Imperial screws and bits.
            Drew
              Hope this helps.
              That's fantastic info Roger - I'll have to think how to best capture the info on "weird" nuts and bolts in the Tech Section
              Drew
                Thanks Roger
                I have a few "scrap" carbs lying around. PM me your address and I will put a couple of the correct 2BA screws in the post to you, do you just need these two? Post to Germany takes 3 to 5 days so if I post them today you should get them early next week.
                  thanks guys for the help
                  can't see the wood for screws anymore
                  At the moment I still have Gareth staying with me who might be able to help otherwise I might PM you Roger
                    No problem, just let me know if you want them .
