I know it seems like a silly question, but:
Our voltmeter varies between 15v and 11v, not seeming to depend on speed or electrical load (lights, battery charging) and when it goes low, we seem to get fuel pump problems: car dies, we find air in the fuel pipe which needs purging. So, where should the volts be in normal cruising and what does the voltage tell us?
Similarly, the ignition light has been flashing from time to time, and we don't know what it means. It doesn't light up when we switch the ignition on, and we're sure that before last week's new alternator fitting, it did. Looking at the wiring diagram, we can see that it sits between parts of the circuit that would nominally be at 12v, so clearly, it lights when there is voltage difference sitting across parts of the '12v' circuit. Beyond that, we're a bit stuck.
Louise
Louise
