Can anyone help??
After a trouble free 5 hour round trip to Bicester for a show two weeks ago, this weekend I topped up the water & oil this weekend and changed the plugs & leads ready for the Bank Holiday weekend.
As a novice I got two leads in the wrong firing order got a bit over popping and spluttering, then checked the order & got them right and it fired up really nice running best for ages, then out of know where the heat gauge went rapidly to the top, luckily I was only going around the block so turned it off with a load of steam.
It has never gone over half before and I have done some very long trips in hot weather before.
I then after some advice took out the thermostat and tried it with no luck, after a lot of fettling & cut hands, I got the bottom hose off and flushed the system with a garden hose from the top hose, the water came through after about 30 seconds and drained away through the rad into the pan,
I have ordered a new Thermostat and bottom hose (as destroyed the old hose, in getting it off)
Has any one got any ideas what next? how do I check the water pump is working OK?
Gutted, great weekend to go out and its stuck on the drive not going anywhere!
Any advice would be most welcolm
