My '71 Stag, based on the temp. gauge , always seemed to run warm ( temp gauge rarely sits to the left of vertical) so this weekend, I decided to do an experiment. I ran the car until it ran out of petrol. ( I normally don't do this as I don't want crap from the bottom of the tank entering the carbs. ) So if I divide the gauge between E and 1/2 into 10 equal parts, the gauge on empty sat above E at about 1/10.
If others have done a similar experiment, can you let me know where the pointer sits on an empty tank?
Based on this offset, I'm making the assumption that the temp gauge reads slightly higher too.
On a Mk1 Stag if the needle of the temp gauge is vertically pointing down, what is the approx. engine temp?
Regards, Sujit
Regards, Sujit
