Aside from slightly lower heat transfer properties does anyone know of any downside to using neat antifreeze?
Coolant Mix
Toyota red, 60 water - 40 red. Leave it in for 5 years allegedly, although I might change it at 4 years. Careful though as there are 2 Toyota reds I believe, don't buy the pre-mixed, get the neat stuff for vehicles of our age. Best to do a bit of Googling first, but has been recommended here on the forum many times in the past
Keith
Guest
30% glycol 70% distilled water is what I’ve run for years, will be changing it soon while trying (in vain) to cure its leak into the V
Hi Jason, Since I bought my Stag a few years back it always used to leave a little water in the V after being used. I guessed it would be the pump or the inlet manifold at fault. However after I renewed all the coolant hoses and the steel pipe that runs parallel with the RH head, the leak disappeared.Originally posted by stagstan View Post30% glycol 70% distilled water is what I’ve run for years, will be changing it soon while trying (in vain) to cure its leak into the V
You may get lucky like I did???..............
Keith
Anything that puts more load on the pump is not a good idea.Originally posted by DJT View PostThicker, so more load on pump. Cost, although ethyl alcohol antifreeze is still fairly cheap.
30% in water is fine. Change it every 2 years.
Link gives many more reasons why “waterless” is not a good idea.
- Likes 1
