Since this is a modification, I suppose it will go here.
I have a header tank from Chris Spain. EJ Ward has a header tank too. I've looked at photos of both and the plumbing look different for both. EJ Ward seems to use the top radiator hose to fill the system. Whereas CS setup uses the heater to water pump cover to fill the system. EJW uses the original expansion connector, whereas CS uses an elbow connected to the top radiator plug. The original expansion pipe is closed off.
With CS' system, I'm having trouble getting the threaded elbow to line up in the correct direction at the top of the radiator to connect a hose to it. The elbow is facing the bonnet.
Instead of using the threaded elbow, I'm thinking of using a Tee in the top radiator hose to use as a expansion to feed back into the tank. Will with be OK?
I have an email to Chris. but wanted to get other peoples thoughts.
Sujit
Sujit
