I am fitting an electric cooling fan taking off the original engine driven unit, I have read that you should fit a spacer on the end of the crank shaft in place of the old fan unit, is it not possible/advisable to use a shorter bolt to hold the pulleys on?
Fitting electric cooling fan
I am pondering this as well..
There has been some talk regarding under bonnet temperatures, the theory is that the original fan is always moving some air around the engine bay.. which helps keep it cooler.
Its been 102 degrees F over here (39c) this week so I'm tending towards the both of them!! But perhaps not a full size electric fan, maybe 2 smaller ones in top right and left positions so that it doesn't block the airflow but can assist, plus come on after engine shutdown to help with heat soak...along with the electric EWP I'm planning on.
Comments??
TerryLast edited by trunt; 5 July 2018, 19:04.Terry Hunt, Wilmington Delaware
Mike Allen the Club technical consultant told me not to do this.
He says it will raise the temp in the engine bay. The mechanical fan is turning all the time, obviously, and this moves air through the engine bay all the time. This is useful particularly at low speeds when the forward motion will not force much air through the radiator.
The electric fan will respond only to the water temperature so the rest of the engine bay could get hotter even if the water isnât hot enough to actuate the fan.
- Likes 2
Originally posted by Jonat127 View PostMike Allen the Club technical consultant told me not to do this.
The electric fan will respond only to the water temperature so the rest of the engine bay could get hotter even if the water isnât hot enough to actuate the fan.Dave
- Likes 2
I found that due to its body design the Stag will not cool adequately on ram air alone, the temperature guage will forever be going up and down and the fan cutting in and out.
Fitting a TR6 spoiler totally alters the situation though, and the car cools perfectly adequately on ram air alone (except when stuck in traffic)
I have Two Stags running electric fans and no mechanical fan, but both have front spoilers fitted.Neil
Originally posted by Lingen View PostSteve.
The load on the engine will merely be transferred across to the alternator. The power to run an electric fan has to come from somewhere!.
JonnoWhite 1976 build ("Mk2") only a few mods
Originally posted by CJG View PostHi Neil
Do you have an opinion on the LD secret spoiler.
Chris
The science behind it looks sound. As I mentioned earlier the Stag is the only Triumph I can't get to cool by ram effect alone, though so saying, both my Toledo and my TR have front spoilers fitted,
Fitting the front spoiler to the TR totally transformed its high speed handling,
My Estate does not have a spoiler fitted, but the number plate is mounted below the front panel air intakes as standard (note the position of the number plate on Tony Harts racing Stag). He fitted it like that for a reason!
- Likes 1
Originally posted by flying farmer View PostI found that due to its body design the Stag will not cool adequately on ram air alone, the temperature guage will forever be going up and down and the fan cutting in and out.
I have fitted a tr6 spoiler and only run a electric fan. The electric fan rarely comes on unless sitting in traffic or engine heat soak after a good run. I have also noted that the engine exhaust manifolds cool down so much quicker now I have stainless steel manifolds fitted .
