just got back from Silverstone, beautiful day top down all the way. The car never missed a beat, didn't overheat but that's what I expect. The problem was the amount of heat coming up into the cabin thru the tunnel. The metal shaft of the gear lever (auto) was almost too hot to touch and the whole area was emitting a lot of heat.
I know there is the usual underfelt type insulation under the carpets but that does not go as far as the gear lever. Also I believe the 2 centre exhaust silencers would originally have had heat shields, is that correct?
I could easily fabricate some alloy shields and space them off the floor between the floor and the silencers but I think a lot of the heat in the tunnel is engine heat being directly off the heads and down and into the tunnel and shields above the silencers would not stop this
The heater valve shuts off fully ( ie the lever goes as far as it can possible to go) but I suspect there is a trickle of coolant still going thru the heater, has anyone used an auxiliary, say a 15mm plumbing ball valve to ensure the coolant is fully shut off from the heater?
Any bright ideas guys how I can keep the cabin cooler? - Alan
