Hi all.
I've developed a wee problem with the window motor on my drivers side. It has been working well, but is now raising and lowering by only two inches or so and then stopping. If I repeat the process often enough it gets to the top or bottom but not in one go if you understand. If I assist the glass by hand it helps a bit but still stops every two inches or so.
Before I dive into the door, could anyone suggest what I am most likely to be looking for ?
Thanks a lot.
Thanks a lot.
