I’ve just replaced the inlet manifold gaskets and had to helicoil a few holes. In order to do this I had to remove the distributor to get to one of them. I’ve now put the distributor back and I now need to set the timing, my question is even though the book says 12 degrees BTDC for my particular engine, as I replaced the points with electronic timing should the timing be different?
Also is it advisable to adjust whilst the engine is running as long as I wear appropriate gloves?
