Carburettor reconditioning
    I’ve been told by a garage, where i’ve had some work done, my carburettor needs reconditioning. Can a knowledgeable member please recommend a specialist company in the Maidenhead area and if possible give a rough idea of the cost.
    Many Thanks.
    Hello JimB
    Moved this into the main SOC forum as I think you are more likely to get responses. here
    what carbs? Strombergs?
    any idea what needs doing with them? most garages that I visit these days don't want to go near carbs and I ended up doing them myself. not rocket science and fairly easy to do.
    You can buy a recon set and exchange yours depending on what they are, but it is likely that they may still need baselining and then setting up properly
      A couple of other Stag owners I know have had reconditions Stroms, with poor backup service, that they ended up re-refurbing themselves, so be wary of that route as the cost is not insignificant..
      Jonno
        Assuming they're the standard Stromberg carburettors, I've heard good things about these guys - https://burlen.co.uk/ They're based near Salisbury and might be worth talking to. Good luck.
        I love deadlines - I like the whooshing sound they make as they pass by!
          Are you talking about Strombergs they are straight forward you just have to make sure you have good parts I did mine for about $100 in parts and that included buying the same part from different suppliers. I also have another set to do when I have time. Read up on them and decide plenty of advice here.
            I did mine myself last year; used the guide on buckeyetriumph's website and bought the repair kits from Burlen. The only thing I didn't replace was the jet as I believe this need specialist tools to fit
