What is the correct route for the BW35 breather?
    I haven't had time to read all the tread on the other BW35 question, so asking a direct new question. On my Stag it connects to the transmission and then hangs down by the exhaust pipe. ( An inverteded U ) Is this the normal route?
    Sujit
    On a RHD model from the transmission it comes up the bulkhead (firewall) across the top under the scuttle panel into the O/S inner wing, possibly the opposite on a LHD
    Rimmers catalogue gives an idea of the route https://www.youtube.com/channel/UCpv...i8vLEpevLPNXkQ
    Nigel
      Sujit.
      The rubber hose connected to the gearbox should be loosely strapped all the way up the dipstick tube. It then goes across the bulkhead, over the top of the brake servo, and terminates after passing through the nearby aperture in the inner wing.. Not very sophisticated!
        Try to vary position so garage floor gets an even coating of oil.
        Andy S
          Silly follow up question, on the odd occasion when my BW35 dumps transmission fluid, where does the fluid come out from? I thought all t his time, it comes out of the breather hose. I dont want fluid coming out of the breather hole if the end of the pipe is sitting between outer and inner wing.
          Sujit
            It comes out of the top of the dipstick, its not sealed, only a felt washer, the breather is higher passing over the top of the brake servo.
              Sujit
              Why not, it stops rust.
