Hi just get the car running after fitting a new alternator. Five mins or so sat running temp gauge is rising then goes to the red line!. The electric fan has not come on don't know why. Fan is set at 70 deg turn the thermostat up nothing turn it down fan comes on at 30 deg. The fan temp sensor is inside the top hose fitting. Check to hose, it's cold! check rad it's cold and even temp all over. Squeeze top hose i can here the water gushing through. Carefully unscrew top rad nut (mk 2) while engine is running water starts to gush out but is fairly cool. Any ideas?, i'm thinking temp sensor on the block must be faulty.
Sorry for the long explanation!. john
