Hi Guy's,
I need some help. I have a 75 Mk2 with a Rover 3.5 Rover engine fitted, apologies to the purists, it's not the engine I love its the styling... the car drove beautifully 3 months ago after spending about £8k sorting the underneath stuff out. The last two times I have taken it out it has overheated to the extent that the gauge is touching the red. I have run the engine a few time with the expansion cap removed watching for bubbles and topping up as necessary, it appeared that all the air had been removed, it made no difference to the temp.
My main question is, would the car overheat if the only fault was a stuck heater lever not allowing hot air in the car, would this mean no water is entering the heater matrix. I ask this as if the lever was in the cold position this surely would not cause the engine to overheat. A few people have said it's this which is the issue. there is no heat entering the car.
There also seems to be a bolt at the top of the radiator where the top hose is, is this some kind of bleed device? I haven't taken the thermostat out yet as it seems to reach a temp then the water leaves the expansion bottle which I assume is the thermostat opening. I do have an additional heat controlled fan fitted.
Just had another thought, if the thermostat wasn't opening would this also stop hot water going to the heater, is this a possible problem?
As you can tell I am no mechanic just trying to keep her on the road rather than be in the garage.
Any help would be really appreciated. I have never driven more than 15 miles as initially, it would break down, now all appears to be sorted and it overheats. Gutted.
