I noticed last night that the driver door LED puddle light still glows after parking the car. I guess its getting some power from somewhere. Mk 2 with Neg. switching. Any ideas ??
LED door light bulb
I would suspect there is a high resistance route to earth through another component in the circuit. I had a similar issue trying to install a lights on buzzer via the drivers door switch. The buzzer still sounded (though only slightly) with the door shut. I have not done anything further yet but suspect I will need to fit a diode in circuit to prevent the feed back. LEDs need very little current to activate hence it is happening but not seen with a standard lamp. Dave.Dave.
Expert:- Ex is something that has been and spurt is a drip under pressure.
Thanks Dave. I was thinking the same thing. Its just a small amount of elec. that's getting to the bulb. Its not on while the parking lights are on. The door switch works a it should Jon as its only the puddle bulb that glows. Thinking about it.... I did fit a headlight on warning buzzer on the door switch so long ago that I've just remembered it. (It doesn't work...) so maybe its still connected.
