Front seat foam refurb
    I needed to renew the foam of my from seats so decided to add adjustable lumbar support. When I dismantled the seat I found that the webbing was shot so replaced this as well. I don't need the adjustable support with the new foam and webbing but it's there just in case.
    when that webbing stretches you can undo an end and then strech it,but I like your idea of a vacuum pump for lumped support
      Thanks, it was the cheapest option I could find. I didn't show the bulb that it is pumped up with. Just like using a BP machine at work.
      Since adjusting the seat hight properly I have just pumped it up a tiny amount for perfect support.
      I did the squabs as well and now have the seat adjusted to its lowest setting instead of highest.
