Hi all, does anybody know what size thread the wheel stud/nut is. One or the other is stripped. Is the stud easy to replace. Many thanks. Mark
Wheel stud/nut
Hi Mark, Stud is 7/16. Easy job to do just tap the old stud out with a small hammer and push then tap the new one in as far as you can. You will then probably need to pull it in to its final seating position so get a large nut that goes easily over the stud to act as a spacer and then just do up a wheel nut over the top of it to pull the stud in. I have some spare studs but am on holiday until next Sunday if your still stuck by then.
Regards, Steve
Originally posted by markmark2 View PostHi all, thanks for all the advice. On inspection I found that 2 nuts had stripped threads. (Not by my own hand!) Will order replacements. Cheers.
MarkStags and Range Rover Classics - I must be a loony
Sorry did not explain properly, some of the stainless stag wheel nuts for the original wheels have been made wrongly and have a undersize shank/spigot section which locates the wheel centrally, giving wheel balance type problems."The UK,s 2nd Most Easterly Stag" Quad Exhaust- ZF 4 Speed BOX
- Likes 2
