Hi,
I'm going to be treating several rust spots on the underside of the car. The areas are small, say 20mm x 5/10mm max. (that's before I start scraping the paint off!). I intend to scrape off any lifted paint with small scraping tools, the areas are way way too small and inaccessible to use a fierce 115mm angle grinder but I know rubbing these small areas down with grit paper is going to be a right pain and will probably rub/scratch too far beyond where I have scraped back to the edge of the rust. Is there a small tool that would be really good for this? I can only think of a Dremel but I have only heard of the name, I've never even seen one so am just starting to research them. I can see that there are corded and cordless ones. And what type of heads to use? I can imagine that the sanding bands may be good but is there a head that can be used end on as well? I imagine it will be something akin to working like a dentist.
I hope that makes sense. Are there any members out there who could advise me on what I need? What type of tools, cordless, corded, types of heads etc etc. scrapers and so on.
Incidentally, when the spots are rubbed down, I intend to paint over with a rust convertor, then an epoxy mastic 2 pack resin primer.
Thanks very much in anticipation for your help.
Mark
Mark
