Hand brake light switch
    The switch on the hand brake which operates the Handbrake light is loose. If I press it hard against the hand brake it make contact and works. It seems to be fitted with one anchor point at one end. I looks like the plastic has curved slightly at the other end. . Any recommendations how to remedy this?
    Sujit
    I'm having problems with mine...but not the same. if the light operates correctly when you apply pressure to the switch..the wiring must be ok (My problem) so replace with a small micro switch to do the same job.
    Phil
