will some distributors fit a Stag
    Someone on a US forum says a distributor from a RV8 will fit a Stag. Are the bodies interchangeable? I recall that the RV8 distributor rotates in the opposite direction so the guts will be no good.
    Amazon US has the following listed. I see there are no hold down clamps
    For the price if the electronic ignitor works and the vacuum advanced unit is the same, this isn't a bad price.
    Sujit
    I think I once looked at this, and from what I recall the Rover is too big a diameter to fit the Stag block as well as everything else being wrong
      It's a relatively common swap down under to fit a Ford V8 distributor with Bosch electronic ignition.
        More information on this swap?
