Trickle Charging
    Trickle Charging
    Just about to put her away for the winter and connect up a trickle charger. Do I need to disconnect the battery or can it be left in circuit to save having to re-programme the radio and alter the clock?
    Thanks in anticipation
    Maurice
    Maurice, I have a C-Tek trickle charger that is wired in to the battery and is left on all the time that the car is in the garage, so the simple answer is yes - connect without disconnecting the battery providing the trickle charger is modern enough to have the "off when fully charged and back on as voltage drops" feature. Regards, John.
      +1
        I use a C-Tek charger too and leave battery connected with no problems...
          Thanks all
          Maurice
            +3 for the C -Tek which I've had 5 years AAAAAA nnnnnnnn ddddddd for the Medion ALDI trickle charger which is on offer from them ( and Lidl , not sure if same model) for £13 ...yes £13 I 've 3 of them and can't stop buying , they are such GOOD value ! And £70 cheaper ( although admittedly with less optional charge cycles ( which you rarely use)...Just buy them when you see them...3 years warranty ! How can you go wrong ?
            Micky
              The charger won't care if the battery is left in circuit or not, but for safety's sake, you ought to disconnect it - many classic car fires originate in a faulty alternator, and they are directly connected to the battery. Us a "Discarnect" or similar for ease.
              Stags and their electrics are not getting any younger.
                Micky
                Wow, that's cheap. Would you know if they're suitable for motorbike batteries? I know my c tek has a bike setting although I've never tried it!
                  I have had one for 4 years or more and yes, they have a motorcycle programme.
                  Ready to buy another when they are available again.
                  Nigel
                    Nigel
                    thanks
                      Guess what ? new in today !
                      Now connected up and topping up my battery.
                      £12.99 can't go wrong.
                      Nigel
                        Typical, I’m on holiday and they’ll no doubt be sold out when I get home
                          You can order online.
                            sold out on-line!
                              Despite it being sold out on-line there are plenty in our local store so picked up two. They come with a 3 year warranty
                              Thanks for the tip off.
                              Bruce
