Guys,
I've got a small drip of oil from the area of the inner driveshaft where it enters the diff. As changing this oil seal seems to entail getting the inner flange off the taper shaft and, as far as I can determine from the ROM, removing the bearing, is this going to be such a pig of a job as the outer driveshaft bearing and flange requiring 10 ton presses?
I can't just replace the oil seal without splitting the set-up can I?
Drew
Drew
