Need help sourcing wheel nut for classic Wolfrace wheel
    I have some classic 70 Wolfrace wheels and am looking for 4 wheel nuts. Does anyone know where I may be able to source some?
    I didn't take any measurements of the nut other than you need a 21 mm socket to remove it
    Photos attached of wheel and nut.
    Sujit
    This gallery has 2 photos.
    Is the wheel nut in the picture for the wolfrace wheel, if so there's similarities to a stag wheel nut, have you tried to see if a Stag wheel nut would fit
      30 seconds on google - https://www.ebay.co.uk/itm/16-Wolfra...-/172735087158
        Hi Dave, I have similar Wolfrace wheels to you. I managed to find a company on EBay selling the sleeve bolts for the slot mags. I can't remember their name as it was a couple of years ago. But I can remember they were based in west London not far from Heathrow airport. The size of the nuts were stamped on the hex nut as 7/16". I hope this helps.
          As per my link, they're in West Drayton
            Thanks for the pointers. Yes! The photo of the bolt is for the Wolfrace wheel. its made of steel compared to the ally ones for the Stag.I think the collar is different than that of a Stag's nut.
            The car the wheels came off had a wheel lock on each which had to be hacked off. I only need 4.
            Sujit
              Hi, I got my SS nuts from
              illstonandrobson1908 an ebay seller. The quality is very good and they fit perfectly. The first set I bought was fromm another seller which was of poor quality chromed mild steel within one year the chrome had started flaking and the washers were also quite thin and not the correct shape for the wheel nut seats.
              Here is some screen shots from the ebay seller.
                Did a bit more searching and found a no. stamped on the side of a bolt 02. Did an ebay search and this came up. (can by them individually by one seller)
                Wolfrace Style, Ford Wheel Nut, Kit Car 7/16 UNF 02
                Does anyone know if Fords used the same nut?
                Sujit
                  Sujit
                  Escorts use 7/16 wheel nuts same as the stag, also the later Dolomite Sprint use the same wheel nut thread,, I modified steel Stag wheel nuts to fit the Sprint wheel
