The foam on the bases on my front seats are sort of OK. Will changing the front seat diaphragms alone help with firming up the front seats?
I used rubber seat diaphragms from Rimmers on another set of Stag seats and they didn’t.
I need to work on a second set of Stag seats. I spoke to Jim and South East Trimming and he says his diaphragms are better than the ones Rimmers sells and need to be stretched more. Also, he mentioned the holes around where the clips go are stronger and thicker. Can anyone confirm this?
I know the seats are handed, but I don’t recall seeing that the foam is handed and I assuming the foam for both seats are the same. Is this correct? I may consider swapping the foam.
Sujit
Sujit
