I seem to have 2 carburettor vent systems fitted to my car. One is a small bore steel pipe system with rubber elbow and tee fittings very much as shown in the workshop manual. This system connects to a fitting on the cast inlet elbow on each side of the engine and, according to the manual, should connect to the back of the air filter.
However on my car it isn't connected as there is already a hose connected.
The second system consists of 1/2" hose and plastic tee-pieces and is connected direct to the carb body on both sides and then to the air filter. See attached pics. I had assumed that these larger hoses were part of the engine breathing system, but they seem to connected together and then connected to the filter box.
