Can I use a spare input shaft to help align the clutch to the fly wheel?
clutch aligment
Originally posted by sujitroy View PostCan I use a spare input shaft to help align the clutch to the fly wheel?
I have also used the input shaft from a Dolomite Sprint simply because I have one spare. The Sprint input shaft is smaller, but the outside diameter of the splines on the shaft is a good match for the inside diameter of the splines on the clutch plate.Neil
luxury if you have a spare input shaft.
replace the brass spigot bush in the crank while it is apart, they are a consumable and unless you know how many miles your has done it makes sense to change it.
For those who do not have the luxury of a spare input shaft I found that a couple of 1/2" sockets and some threaded bar was almost as good
As a habit I never fully tighten the clutch cover plate 1st time round. nip it up just enough that the clutch plate stays put, offer up the gearbox, when the splines engine, carefully remove, nip up the clutch cover bolts, making sure that the stag items do not bottom out in the flywheel and then refit the gearbox.
with an input shaft handy you shouldn't need to faff around like that thoughStags and Range Rover Classics - I must be a loony
Easiest way I find is to assemble the plate and pressure plate finger tight on the flywheel and manipulate the clutch plate until its edge sits the same distance all round the pressure plate edge, you can usually see this distance easily in three places round the pressure plate. Quicker and less fuss, especially where alignment tools have 'tolerances' and you have to guess it is in square.
I've always done it that way and have never missed, it saves trying to align the alignment tool properly.
JohnYour wife is right, size matters. 3.9RV8
Originally posted by jakesmig View PostEasiest way I find is to assemble the plate and pressure plate finger tight on the flywheel and manipulate the clutch plate until its edge sits the same distance all round the pressure plate edge, you can usually see this distance easily in three places round the pressure plate. Quicker and less fuss, especially where alignment tools have 'tolerances' and you have to guess it is in square.
I used to get an appropriate sized allen key to use as a gauge for the gap between pressure plate and clutch plate.Terry Hunt, Wilmington Delaware
