BMW servo
    BMW servo
    Hi
    Any one fitted a BMW servo to there car,I know originally they were from a E30 but there hard to find now,I've got one from an E36 ,what dia m are the original E30 ones
    Thanks Dave
    Dave I will try and get in my stash tomorrow and take a measurement you do know that you need to modify the inner wing
    with a lump of wood and a large engineers tool. Also a extra plate to strengthen the firewall as the new holes are very close to the stag ones.
    Graham reminded me of this on my visit to Tenerife.
    Cheers Glenn
      Also they are a right royal pain to fit on a manual , much easier if you have a special needs gearbox as you dont have to move the clutch master cylinder. tbh a decent front caliper disc upgrade does a very good job so i wont be doing mine so servo up for grabs
        Dave just measured around the outer edge mine is 86 cm
        Cheers Glenn
          just started using my car after a Millwood 4 pot with vented discs, stops on a sixpence with half the effort of the old discs
            willwood...auto correct
              Cheers Glenn
              Glenn
              Thanks, yes I did know about the inner wing
                I've fitted the wilwood brake kit
                  mine is as you call it special needs
                    Me too - excellent upgrade, nicely progressive but very powerful.
                      Where did you buy the Wilwood brake upgrade from, I have never seen any advertised.
                      1978 mk2 with Rover 4.2 V8 fuel injected, Datsun half shafts, rear disc brakes, Image 15" wheels.
                        Got mine from Faversham's; they did an excellent job of fitting them too, while I took Trevor's dog for a walk!
                          Robsport - easy to fit and the full kit too
                            slight differences in the 2 kits, personally...faversham
                              I made my own kit,bought the calipers,etc ,it did help that I helped someone fit there own kit
