speedo problems
    speedo problems
    Hi
    I have a puzzle
    My 1973 stag when doing 60mph is showing 4000 revs
    Other stags I have driven show 60mph at 3000 revs
    The gearbox has just gone through a major service with a professional who also owns and runs a stag ..his stag also is doing 60mph at 3,000 revs
    This mechanic specialises on BW 35 and 65 gearboxes and has checked out
    The differential ratio which is correct
    The speedo cable which is fine
    The colour of the cog on the back of the speedo which is correct
    I believe the Stag was originaly fitted with 185/14
    My car is fitted with 195/75 R14
    Is this causing the difference shown on the rev counter ?
    If not ..any other possible causes ? ..perhaps the speedo head its self is untrue ??
    Any help or insight would be appreciated..
    Paul
    What speed does a satnav show when the car is driving at 60mph?
    A better easy to use tyre size calculator. Use our tyre size calculator to find tyre diameter, width, sidewall, circumference, and revolutions per mile.
    185/70/14 shows 834 revolutions per mile, 195/75/14 shows 791 revs per mile, or about 5% difference not the 33% you are reporting.
    Difficult I know to corroborate but does the rev counter seem to be reporting the rpm correctly? There are cheap electronic rev counters on Ebay for £10 to £15 that couple to the ignition coil and you can jury-rig in a few minutes if you need to check revs.
    Alan
      f this is anything to go by, I have an auto bw35 stag with 185/70 x 14. my rpm at 70 mph is typically 4000 rpm
        I would mistrust the rev counter, mine was reading 50% low until I had it rebuilt.
        Chris
        Magenta Stag TV8 MOD
          download a speedo app on your phone and then you can check revs against speed against what your speedo reads
          my zf auto box is 3000 rpm at 80mph
            Hi Paul, the mechanicals must be correct, there is no scope for a variation other than minor such as tyre diameter so it must be calibration of instruments as the root cause of such a large variation, try a drive with a friends car to compare speedo or as suggested a back up to the tachometer.
              As Phil S has suggested, if you have or can borrow a portable SatNav, you can double check your speed by GPS against your speedo.
              Chris
                As always Im really impressed with the speed and feed back from SOC
                Im a sleeping member really but now the car is back on the road Im going to attend a few shows and hopefuly meet some of you guys
                I never thought of checking with a sat nav and thanks for the calculation I would have a clue how to do that ..im please its only 5% variation on the tyre size I was worried im burning more fuel because of more revs linked to the larger tyres
                When im doing 60mph the rev is def showing 4,000 revs ..but obviously now Im thinking im doing 70 not 60 as the car is revving high it seems to me ..if its the speedo thats out then when im doing 70 im really doing 80 which is very worrying as Im liable for some speeding points
                The ZF box is a nice piece of kit I was seriously thinking of it if the mechanic had condemned the gear box ..initially it went to him because it wouldnt change into 3rd unill it hit 3,000 revs but if the rev counter is out then it changing into 3rd at 2000 revs in reality or am i losing the plot ?
                It was only when I spoke to him as he runs a stag that the 1000rpm diffidence came to light
                My way forward think is sat nav to check speed to put my mind at rest so Im not going to get done for speeding if the speedo is out..I wonder if would get away with a prosecution it if I could prove after the event that the speedo is faulty ? ..just a thought
                Buy a cheap rev counter to tie into the coil to check revs .. but technically if the sat nav proves the speed is correct then the rev counter has to be faulty there is no other conclusion
                Im picking the car up on Sat Il let you know how this plays out
                P
                  My rev counter was rebuilt by these people Speedograph Richfield, it’s worth ringing them first. Then send your tacho, they assess and call or mail you. You approve their estimate, they let you know when it’s ready and you pay and it arrives in the post. About a two week turnaround. It seems a bit of an antiquated way to do it, when I asked they said that some people back out when they find out the costs. Mine was £85.00
                  Home - Speedograph Richfield specialises in providing high-quality range of motoring instrumentation, drives, cables, miniature gearboxes and other components.
                  Chris
                    Great thanks Chris Il contact them ..
                    P
                      Have you done the SatNav test yet?
                      Chris
                        Not yet
                        Im picking the car up on Saturday ..at 10am then a 2hr drive home so I can give it a good test then
                          This may help with RPM vs speed. I used it when I converted my Mk1 Tacho to digital.
                          This gallery has 1 photos.
                            Mine works out to 3000rpm at 60mph, so at 4000 it is doing 80, all checked against a GPS.
                              Hmm.thats what Im worried about..Ive already got 6 points cant afford any more ......Im off to Baldock at 8 to pick the Stag up so il up date the finding here Ive downloaded a speed app to double check actual speed
                              P
