Hi all
Less than a year ago I had a misfire at around 2800rpm, which I found after much assistance here to be either the coil or the leads. I replaced the coil first, which improved it, but the misfire was still present. When I replaced the leads, the misfire disappeared. I checked and had two wires with very high resistance. These original leads were about a year old when the misfire developed and installed by Faversham (green silicone versions). I replaced them with a new set of green silicone ones.
However the problem has now returned. I checked the resistance and found one has very high resistance compared to the others.
Are these green silicon leads particularly delicate? The only time I took them off in the last 8 months or so was to do a compression test.
I am wondering if my tidiness in using the cylinder head clips is damaging the internal wiring?
Any thoughts?
Jeff
Any thoughts?
Jeff
