Hi All,
the current system of removing the filler bolt from the top of the rad every time you want to check on the water level (this for me is each time I use the stag) is long winded and always has the terror of ripping the elbow out of the rad.
I am looking at weld on type filler necks with a sealed cap, I have been toying with making one of these with a 1/2" bsp thread to fit in place of the current filler bolt.
this would make checking the coolant level a simple task.
I would value suggestions and input prior to going for it.
Thanks Phil
Thanks Phil
