Engine id
    Engine id
    Is there a register i can check to see if my engine is the original factory fitted engine?
    Get yourself a Heritage Certificate: https://www.britishmotormuseum.co.uk...e-certificates
      what are the letters at the end of your engine number. might save you a few quid on the heritage certificate if you have a factory recon engine fitted
        HE at the end
          Talk to Peter the registrar to see what info he has on your car, he might have some interesting info, but the heritage cert will tell you all, along with where it was sent from the factory key no's etc
          The yellow team
            Yes, good stuff - have talked with Peter already and it turns out we are the 4th SOC registered owner (out of 18 previous owners!!!). This car UNY 49M needed us - or it was probably only good enough to be doomed for spares or scrapping! Best TR T!
