As I posted on the 'What did you do with your Stag today' thread, I have started to notice a bit of a noise from the nearside/left side front suspension, and on inspection it seems that the spring is rubbing on the tower. I had this before - after (disappointingly) a well known and reputable Stag Specialist had replaced the front shock absorbers about 8 years ago but not refitted the spring in the correct orientation. I corrected this and all was fine. But now it's rubbing again - I suspect the spring (the original from new) is tired and has bowed a little.
The rubber gaiter on the shock that side is also very rucked up - the offside looks fine.
It would appear that I ought to fit new springs, and probably whilst doing it new shocks again.
Is this a straightforward job bearing in mind I don't have any specialist tools, or should I trust it to a (different) specialist?
The car is a completely standard 1974 model, and I would welcome thoughts on the best specification and source of the parts I should go for.
