Hi I have had a problem a few times starting had the normal ignition click would try several times then would start and run fine. This has now got worse I came to stopping then turn key off and engine would continue to run. I have cleaned all terminals on starter motor replaced ignition cable but now when I go to start ignition light comes on but stays on even with key removed. Sorry its a long post but any ideas would be gratefully received.
Ignition light stays on
As Drew says could be ignition switch. To rule out alternator why not simply disconnect it? If car starts and stops normally (ignore ignition light which will obviously be on - no alternator, no charge) then it was probably the alternator. If the fault still exists then look at the switch.
A bit more analysis/diagnosis is required before condemning the alternator.
RogerNow Stagless but have numerous car projects
- Likes 1
Originally posted by dasadrew View Postif the engine continues to run and the ignition light stays on when the key has been turned and removed, doesn't it sound more like a wiring/contacts fault in the ignition switch?
Drew
Keith.
Originally posted by Kithmo View Post
Not necessarily, the permanent live feed to the alternator (thick red wire(s)) goes back through the short circuited diode pack and up the ign wire to the switch, feeding the ignition circuit. So the engine may stay on even without the key in. As Roger says, disconnect the alternator, the light will stay on when running and go off when turned off.
Keith.
DrewThe answer isn't 42, it's 1/137
Keith.
With your system as is, suggest you switch on the ignition and look at the voltmeter on the dash (allowing time for it to stabilise (say 1 min) - should be 12 - 12.6V dependant on its state of charge. Start the car and hold the revs at 1,000 - 1,500 and look at the voltage again. If the volts are climbing up to 13 - 14.5, then this indicates your alternator is OK. If volts still ~12V, then alternator is suspect. If volts climb up, then it's pointing to a fault in the ignition switch block.
Replacement alternators seem to be available for ~£50, so if you do need to replace it might be worth considering getting an uprated one..
Jonno
PS - just checked the interweb on spinning a disconnected alternator. What I said above seems to be correct, though several folk seem to have got away with it - you feeling lucky?
- Likes 1
Good point Jonno, I forgot about that. I ought tto know that as I had two alternators killed on my old escort van when there was an intermittant connection / break in the positive lead to the alternator.
Note to self think things through before giving advice!
I just didn't like the idea of condemming the alternator without further investgation.
As he has the ign light on with the ignition switched off, he can still disconnect the alternator, but not start the engine, to see if the light goes out. FWIW the alternator won't start charging with the ign wire disconnected until it gets to around 3000 rpm so it's ok to run it on tickover.Last edited by Kithmo; 31 May 2019, 13:03.
Originally posted by Kithmo View PostAs he has the ign light on with the ignition switched off, he can still disconnect the alternator, but not start the engine, to see if the light goes out. FWIW the alternator won't start charging with the ign wire disconnected until it gets to around 3000 rpm so it's ok to run it on tickover.
Jonno
