I don't know why just now, but I thought I'd look at my ignition timing to see if I can get the engine smoother at low & idle speeds. Went to the ROM to refersh my memory and read:
Dynamic Timing:
pull of vacuum advance pipe
run engine at 3400 rpm
strobe light should show 16 - 20 degrees of advance above the 14° BTDC of static timing, this means the strobe should show 30° - 34° advance, but the metal scale only goes up to 24°
In the table at the beginning of hte ROM chapter it states that centrifugal distributor advance at 3200 rpm should be 12° - 14° and crankshaft advance at 3400 rpm 16°-20°
I've set mine up to be 18° measured at the metal plate at 3400 rpm. Am I doing something wrong, or has the ROM tied itself in knots?
I'm sure this has been done to death in the forum, but I haven't been able to fathom out this conundrum from the posts I've dug up so far.
Can someone enlighten me?
					Dynamic Timing:
